MartyMart
Here's some Farnell codes for the stuff I ordered for the D_AOC.
It's NOT complete, as I had some things anyway, but hope it helps
save the 2+ hrs that it took me to find it all !!
Capacitors -
100uf 50v ( 35v use ) 969-6660 NOTE this is a "bipolar" and probably wrong - intended for the Pico Comp board
47uf 350v 969-6440 12 needed
1000uf 25v 969-2193
2200uf 35v 969-2347
3300uf 25v 969-2223
Poly -
0.22uf 400v 116-6132
1uf 400v 116-6136
0.1uf 400v 121-5494
Resistors -
470ohms 2 watt 933-8250
2k2 2 watt 933-8160
10k 2 watt 933-8063
39k 2 watt 947-5257
100k 2 watt 933-8071 ( all 10 pieces minimum )
1M trimpot 935-4328 ( 5 pieces minimum )
Other -
LM350T 131-7673
TL783CKC 959-4582
1N5371 955-8284
1N5400G diode 145-8988
1N4007 diode 146-7514
5w zener 39v 955-8233
Heatsink - undrilled 232-968 ( bigger one to attach to case for heat dissipation !! )
Heatsink - board 121-9493 ( matches board pattern 2 needed )
VTL5C4/2 - ordered from ; www.smallbearelec.com
Transformer/ solen fast 10uf/ tubes and sockets ordered from
www.musikding.de and found very easily.
Marty.
EDIT - Board arrived whilst typing this![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks Volker .
EDIT - I had the numbers spaced out evenly but it goes away in "preview"
and when posted !! - **** !
Capacitors -
1000uf 25v 969-2193
2200uf 35v 969-2347
3300uf 25v 969-2223
Poly -
1uf 400v 116-6136
0.1uf 400v 121-5494
Resistors -
2k2 2 watt 933-8160
10k 2 watt 933-8063
39k 2 watt 947-5257
Other -
LM350T 131-7673
TL783CKC 959-4582
1N5371 955-8284
Marty.
Thanks Volker .
