[silent:arts] said:for the Meter:
the circuit is taken from the LA2A
(which uses a VU Meter)
btw, there is a 3K9 resistor needed in series with the VU which is not on the PCB
(since I wanted to have a switchable "Gain Reduction" / Output VU)
some comments from Keith:
http://www.groupdiy.com/index.php?topic=25646
and how to calibrate it:
http://www.groupdiy.com/index.php?topic=23253.msg276178#msg276178
(R25 = R126 & R226 in the D-AOC)
I had the same issue with the neon lamps. I simply swapped it with another one and all was fine. I still have a couple of 'm left just in case, I bought them back then in a set of 10 I think.Jonkan said:So I swapped the neon lights for the zener diodes in the meter circuit. Now the meters are stable and working properly, but both channels has a big HUM instead! *fail*
Any ideas why? and how to fix it? The meters werent stable with neon lamps, but audio was working perfectly.
Both channels are still working correctly and compresses, gains are working etc, except for this hum that is making me want to tear my hair out and sell this project for a loss and some broken self esteem.
Any help is greatly appreciated, im about to give up on this...
/J
Jonkan said:Thanks for the encouragement! I just dont know where to start... I tested all the voltages and been moving the toroid around, changing grounding...
Could just changing the neon lights to the zener diodes have caused this hum??
It was working perfectly before except for the meter jumping around a bit before this!
/J
