Pusch3l
I stick with Frank from Frontpanels.de and i think the other German Guys here too..
audiophreak said:Hello All,
I'm about 2/3 completed with this project including the Kubi Mods , Can someone point me to where I might find info on how to hook up the " Curve " LEDs when using two Vactrols, I've seen a couple pix of others builds, but they only had one Vactrol installed.
Thanks in Advance![]()
protools said:Yes i confirm, they are in parallel with the switch doing on/off on the second one.
Best
WT
Best
WT
protools said:Additional...
try to wire your LL1540 1:2 for 6dB more input levelHobbyist said:it works fine except I need to push hard in to get compression
