iturnknobs
DMP-
I'm having similar questions/issues. My back capsule is not heating up when switched to omni. Your drawing appears to make sense and I have come up with a similar idea. How/where do you propose connecting "crd" and "com" together? Maybe here at the switch? My switch appears to have a common center lug and selects either position 1 or 2. I believe my drawing matches your schematic of the switch connection. This should satisfy the ground for the relay when in cardioid and energizes the relay to make contact for backplate voltage in the omni position.
-Brian
-Brian
