vinylwall said:
I'm having a problem figuring out which way an AMI T47 transformer mounts on the board. The transformer itself has no indication of which pins are A-B or C-D. I looked at AMI's website and they show a bottom pic of the transformer with A-B and C-D but there is nothing that indicates which pins are which. How can I determine A-B and C-D on the T47?
see attached pic. the T47 spec sheet shows the pins labelled A,B,C,and D. As does the PCB, but it is a bit confusing which pins are which on the transfomer itself. Pin A is the one closest to the 'T' in T47 on the pins side of the transformer.
Hope this helps!
