DAW Controlled Wireless Recording Lights
very nice!  I'm designing something similar that uses a studio's wifi network to handle all communications, instead of that proprietary xbee system, which relies on it's own network.    The only problem i'm realizing is that a lot of studios don't like having their main rigs connected to the internet, so i can see why the xbee system was a great choice for this project :)
I'm using xbee's Digimesh system, so there's no network base station or anything like that. Just the broadcast mesh transmitter I designed, which is connected to the DAW and as many signs as you like.
http://glorytron.com/2012/08/wireless-daw-controlled-recording-lights/
Can you offer DIY scheme for NON wireless DAW Controlled Recording Lights?
I look for simple device for my studio.
Thanks in advance.
Eftim
Non Wireless ?! Usb to serial sending a signal when record is on ( midi ?!) . uC with firmware will also do the trick...
Im actualy about to start a similar project ( usb) and as usual ill post code and( if applicable) schematics... In my case is just a midi controller ( pots mainly)...
Soon come !
