I discovered something odd on my board. The bi-color LED appears to be of the common-cathode variety, meaning the toggle switch should determine which anode sees current. However, on my PCB, there is no connection between the lower pin of the switch (presumably compression OFF) and the second anode of the LED. In the picture, you can see that a partial trace was clearly laid in the design software, but it doesn't end up anywhere (and no, there's no via, and I have confirmed this lack of connection with a meter). So even though it is supposed to support a bi-color LED, in practice I'll only be able to use a single color or I'll need to make that connection with a wire. I wonder if I got some early revision of the board and this error was corrected later, since it sounds like others are using the bi-color LED without issue.
