abbey road d enfer said:
I should have said, as I wrote later: "Again, we see the importance of terminology. The signal is the whole signal, including noise and distortion." It's only the fundamental that's identical in the different versions, it doesn't allow saying the signal is equally preserved.
Yes, it is indeed an issue of terminology, and you'll have to accept that you're not entirely correct here if that's your argument. Let me just quote the very first sentence on Wikipedia's entry for "Digital Recording":
"In digital recording, audio signals picked up by a microphone or other transducer or video signals picked up by a camera or similar device are converted into a stream of discrete numbers, representing the changes over time in air pressure for audio, and chroma and luminance values for video, then recorded to a storage device."
So if we really want to nit-pick this terminology the word "signal" is used twice, to refer to two different things:
1. The signal which is the analog input.
2. The "signal", which is really just a set of numbers representing #1 after conversion to digital.
Therefore, it's absolutely correct to point out that we're not describing or representing #1 any better at -10dBFS with 24 bits compared to 16 bits, whereas you could make the argument that for #2 we are. But the discussions on this topic typically have to do with recording, and where people get confused is where they think that the signal that we care about, the input signal, is somehow of higher "fidelity" when described using 24 bits rather than 16 bits, when really the practical issue is again the noise/distortion at the very bottom of it all.
Further more, a lot of people would argue that #2 is actually an incorrect usage of the word "signal", and that all those numbers aren't a signal at all, and that the signal is just what happens after we've reconstructed it from those numbers. So there's no real "noise" or anything in the
signal in its digital form, even if that's what we end up with once converted back to analog. The numbers are simply "data" which represent a signal. Just as there is criticism against what happens between the samples (i.e. the "stair steps" etc, which actually don't exist) there is criticism against calling our data set a "signal", again, because it isn't, it's just a representation of one.
Of course, I find that to be a bit nit-picky again and fortunately such criticism is mild and infrequent, and I think it's sort of beside the point, but it's worth pointing that out if we
are going to nit-pick what I was saying.
So anyway, I absolutely stand by what I hope I said earlier, which was that: By recording to 24 bits rather than 16 bits we push noise/distortion further down and can get more comfortable when recording, not having to worry about recording too close to the noise in order to avoid clipping, and by recording a lower level signal we're
not describing our
input signal with any less detail.
