This is why I tried to avoid this veer, and am surely repeating myself (I'm starting to get used to that around here.).
For low bit/word length that classic number of quantization levels is adequate to characterize a path performance..... But modern high bit/word length systems do not follow the classic behavior all the way down to the LSB (actually a good thing).
There have been numerous tutorials written to explain this better than I will but one important observation, the analog (output) side of D/A conversions is not discrete steps, but a continuous (smoothed) analog voltage, so don't expect to count stair steps.
Modern convertors typically perform an over-sampling conversion at their input. The analog stream is converted at a very high sample rate, but shorter digital word length, then that digital stream is mathematically crunched (decimated) down to a lower sample rate with longer word length. The noise floor is dominated by this oversampling stage and not only analog sounding (hiss instead of grainy quantization) but manipulated to shift noise above the audible band.
When characterizing the behavior of modern high performance convertors try to resist the attraction of digital math, and look to old school analog metrics, like S/N, THD, etc, measured the old fashion way.
Yes listen to the digital noise floor, you will probably hear other gear in your chain, or an analog sounding hiss.
I am old enough to remember when digital noise floors were something you could identify and had to worry about. Lots of time and effort wasted to manage gain structures to keep signal above the dreaded quantization floor.
