JohnRoberts said:
Trying not to repeat myself, and trying to avoid subjective judgements (like this kind of distortion sounds good and that one doesn't), there are clear objective improvements between even the best early VCA hand built by David himself, and the newest generation IC technology. There is a pretty long AES paper from one of the THAT VCA design engineers a few years back, counting the ways.
Not making a judgement, but there are obvious subjective perceived differences between different compressor side chains. The control path would color the sound even if using a perfect VCA that doesn't exist. This IMO justifies the popularity of some classic legacy designs. So even with a near perfect VCA there will be X% deviation caused by the gain manipulation and Y% from the VCA errors. With a lesser performance VCA the X% will still be there but the Y% contribution will be larger. .
I don't want to damp your enthusiasm or inquiry. The open question (to me) is it the X% sound that you want to replicate or the X+Y? Does the larger Y% error added by the old discrete VCA add some useful euphonious coloration, or detract from the goodness of the X%.
Perhaps build them up each way and listen.
It doesn't matter what I think... it's your time and money. Just know what the variables are.
Hiya John,
AC may have a side project in mind with these VCAs, but he's spearheading the dbx 160VU cloning project here. He's completed the pcb and has provided footprints on the board to accomodate a 200 VCA OR a THAT 2180. Some on the build will likely build both on the board and toggle to between the two VCAs.
As for the old BC-109C/BC-263 in the original 200 VCA: there are newer NTE equivalents which we will be using. The tricky part will be hfe and Vbe matching AND keep them thermally neutral (glue???).
I have several dbx 119s which I can harvest 200 VCAs and 208 RMS's out of, but since this is my first foray into building something that's not a guitar pedal, I'm chalking this up as a cheap education and it will be a great learning experience for me. The cost of the entire clone project - including meter and rack will be under $200.
hfe matching seems pretty straight forward. Have you ever done Vbe matching? Is it difficult?
DY
