RuudNL
To preselect the transistors for Hfe, I used the following setup:
Emitter to ground, collector to the supply voltage (+ for NPN, - for PNP) via a 1 K.ohms resistor (I used 10 Volts), base to the supply voltage via a variable resistor of 1M.ohms. Then I adjusted the variable resistor for 5 V. on the collector.
I used a DIL IC socket to make it easy to exchange transistors.
Now, if the Hfe is higher than the reference transistor, the collector voltage will be lower. On the opposite: if the Hfe is lower than the reference transistor, the collector voltage will be higher. This proved to be an easy way to select transistors, although it is time consuming! (Every time you have to wait until the temperature is stabilized after touching the transistor.) With a digital voltmeter you can select them with millivolt accuracy. I tested 50 PNP + 50 NPN transistors and the result was two sets of 'ideal' matched transistors and one set 'almost ideal' matched transistors. All transistors came from the same batch!
