damnyankee said:
You do this for a living, I do Medicine for a living - which is why it's a little difficult for me to follow. Believe me, I get patients who ask me endless questions and I sometimes it takes me exploring several different angles until it finally bells in to them. I know it can be frustrating - and I apologize for frustrating you.
Think of electricity as blood flow...
If the JFET is drawing .56ma at 9V, then the selected resistor must be 16k, correct?
That particular JFET draws .56 mA at any rail voltage when the gate to source voltage is 0V. This output current is like a current source so it doesn't care what the rail voltage is. In fact that drain is clamped by the base of Q1 so it can't go above 1V. Since we want to bias the base of Q1 at roughly one volt (the Vbe of Q1, plus the drop of CR1), we use a resistor between the drain of the JFET and Q1 base and +7.5V supply that will supply roughly the same current as the JFET is pulling down. If you know the beta of that transistor you can calculate that base input current too..
With a 9V supply we still get .56mA from the JFET and still want to end up with 1V to drive the transistor, so the resistor must now drop 9-1=8V. 8V/.56mA= 14.3k
And, altering the resistor value affects the current going to the JFET, correct?
No.. The current is a function of the FET gate voltage relative to source. The selected resistor defines the total current coming down from the plus supply into the base, which minus the current the JFET is sucking back out controls Q1.
Higher valued resistors lowers current to the JFET and it won't operate correctly. On the other hand, Lower valued resistors increases current to the JFET and it won't operate correctly...and if current is too high, *Pop! goes the JFET*.
In the simplest of terms, is this basically correct?
DY
NO.. The current in the JFET is a function of the gate voltage relative to the source. If the bias resistor (R1,R10) is too large a value, it will not deliver enough current to overcome the current pulled down by the JFET Q1 will not bias up and turn on. If the resistor is too small a value it will drive the base of Q1 too hard for the JFET to overcome and control.
Now this static explanation is a little simplified, since the JFET will only have 0Vgs on it at equilibrium. If the VCA is getting too little or too much pull up current from Q2 it will pull the gate up or down one diode drop when it saturates the VCA transistors. But the JFET will draw less than Idss for negative gate drive, and slightly more than IDSS for a positive gate drive so this is additional negative feedback and stabilizes the current in the VCA.
The important concept to grasp, is that the output of the JFET is a pull down current, and the selected resistor supplies a similar amount of current pulling up on the base of Q1. Equilibrium is when these two currents net out close to zero, give or take a little base current to turn Q1 on.
