rogs
The preamp was set with 20dB of gain.Ah ok, that makes sense.
In your vocal sample, how high did you set your mic preamp?
As Khron has pointed out, I should have compared the mic preamp with the input of the Tascam loaded.
With the input pad setting the gain to 0dB, the mic circuitry adds about 3dB of extra noise. With the pad removed, the gain of the preamp is increased by 20dB. And so of course is the noise from the mic preamp!
The Tascam preamp itself adds very little to the noise level.
Without access to a calibrated 94dBSPL reference signal, it is probably best to use a microphone with a known noise level to compare. As already mentioned, I use my Rode NT1 as a reference. It has a published noise level of 4.5dB(A). I would estimate that an OPIC circuit has a noise figre about 3 or 4 dB worse than that. The differential audio output of the Alice OPA circuit will add another 3 dB or so to that figure.
So you should expect a noise figure of around 10 or 12dB (A) from your Alice preamp. Still pretty good.
You might like to glance though these papers from Neumann and Sound Devices, which give some insights on how noise is measured in mics and preamp?
https://www.neumann.com/en-en/homestudio-academy/what-is-self-noise-or-equivalent-noise-level
https://www.sounddevices.com/microphone-preamp-noise
It's not always an easy subject to understand .... I'm still learning all the time!
