I used this dc dc hex board with the single channel alice opamp 1642 board from jli electronics, but it's got just a tad more noise (white noise) added to the signal than i would like. I've attached the schematic of the board.
I tried the dc-dc hex power board in another known fet mic, and it is indeed the dc-dc circuit board that adds small amount of white noise.
Could it be the diodes? I've read that diodes are known to be noisy. Would anyone have any ideas where I can start looking?
I notice from your attached schematic that you are using a 4584D, rather than the 40106 normally specified for this type of circuit.
Pin fpr pin compatible of course, but with a much lower hysterisis voltage. I suspect the frequency of your oscillator will be significantly higher than the c.125KHz normally encountered when using a CD40106 with those oscillator values. ( The HEF 40106 has slightly different hysterisis levels - and that causes the oscillator frequency to rise to around 180KHz ).
None of which should affect the noise figure significantly as far as I can see - ( unless the 4584D is unstable, as suggested by Abbey ? )
The output filters formed by R2/ C2 and R1/C1 should essentially remove all troublesome HF noise. There should only be some 5 to 10mV of measurable residual HF, which is not going to add any significant noise to the polarisation output voltage.
One other possibility for a noise source is less than ideal ground routing. ... If the current drawn by the inverter oscillator is routed via a signal gound route, that might create noise?
What will add some extra noise is the fully differential audio output employed in this OPA1642 configuration.
The 2 x 2k2 resistors included in the inverted audio ouput stage will add about 3dB to the overall noise figure.
I chose to use a single sided audio output for my
OPIC versions of this same concept, to avoid generating that noise.
( The OPIC circuit is impedance balanced passively, to help maintian a reasonable CMRR figure.)
I would guess that any noise generated by the polarisation voltage oscillator would be lower than 3dB ?
