That does seem to have a measurably higher noise level than I have experienced using the OPA 164* series op amps?
The problem with a direct comparison is that there are several variables.... capsule sensitivity, preamp gain, ambient noise levels etc...
I offer the following sample as a refernece which endeavours to exclude some of those variables.
This audio sample :
OPIC.noise.level.wav is a recording of an OPIC preamp, made using this circuit:
OPIC LDC
• The first 10 seconds are of the
unterminated input of the recording device (a Tascam DR100Mk3) wih the gain set to 0dB. The noise level recorded is around -90dB.
• A small 'glitch' sound indicates the connection of the OPIC circuit. There is no capsule connected, although the 1G input resistor remains in circuit.
• The remaining part of the sample indicates the extra noise added by the OPIC ciruitry (between 3 and 6dB of noise).
• There is no HPF introduced -- the recorded noise is full bandwidth.
Looking at the Alice OPA schematic on page 2 of this document:
https://www.jlielectronics.com/content/OPABoardsREV_1.pdf would suggest 2 possible sources of extra noise:
• The 2 x 2k2 resistors shown controlling the second (differential) audio output op amp will allow the audio output to be increased by 6dB, but will also introduce extra noise into the signal path. This should only be in the region of some 3dB - possibly slightly less.
• The Alice circuit shows the power to the opamp regulated by a zener diode. Zeners are notoriously noisy, although one would expect the LPF introduced by the 200R resistor and the 47uF capacitor to control that noise.
Some designers will include a second 100nF capacitor across the 47uF electrolytic, to help with any unattenuated HF noise . Others say this is unnecessary with modern capacitors? ... One of those things that can be confirmed experimentally quite easily!
( The OPIC circuit does not regulate the supply to the opamp. This helps maximise amplifer headroom. A zener is only fitted to regulate the supply to the voltage multiplier, used for capsule polarisation volts.)
Testing your ciruit like this should help to confirm the noise level of the OPA preamp itself, independent of anything introduced by the capsule - or the associated polarisation circuitry.
