JohnRoberts said:
For onesy twosy electronic switching like PFL in master sections i've seen these dedicated switches used, but for larger scale switching needs there are cheaper ways (I was cheap even back then).
Well, if it gets the vote from you guys, I'm assuming the CMOS switching may not present the problems that traditionally I've heard about with them. My knowledge of these devices is coming from the stompbox world, though, and I'm sure you all know how inaccurate some of that information is.
I have long been a proponent of simultaneous peak/VU metering on an LED bar graph. Old school VU meters are eye candy, but not great for seeing what is really going on with a signal, and your financial diet. A simple peak bar graph should be adequate for modern digital media, unless that media has meters that can be monitored instead of reinventing that wheel.
Someplace I remember seeing a bargraph driver chip that had simultaneous peak/VU style metering, which would be an inexpensive compromise. I know VU's are the prettier (i.e. producer drool factor) option, but since this is a desk for me, I only have my own drool to wipe up, and I just don't see the benefit.
This suggests perhaps some refinement of a standard I/O between all blocks. While simple differentials are adequate within a single chassis to reference between local grounds, if these building blocks need to be free standing, I would use a balanced interface between them which increases the total system cost and power consumption. probably logical to distribute power supply regulation to 3 terminal regulators inside each block. This approach is attractive for DIY but not embraced by major console companies because of the cost. Metal work, connectors, etc it all adds up when multiplied by number of channels. In console design you have to think of all costs in terms of a times N factor.
I think I was perhaps not clear in my description of my first design revision by some people's responses. For exactly the reasons you describe, John, this is all going on some cards in traditional console form. While it would be quite neat to offer some standardized 1U modular interface (think BladeServers for you IT folks) that can be swapped with ease, the metalwork, weight, heat transfer, power supply, and interfacing problems would just be too much engineering for something that will probably never leave the room it's constructed in or be used by anyone other than a few individuals over the course of its life.
However, as I said before, all the schematics will be available for anyone to build into whatever modular format that one desires.
Is there any benefit to having regulators on a per-channel basis? The ones I see are reduction of ripple and rail impedance for the channel, but I also see the drawback as being added heat dissipation within the desk itself instead of at the PS. Does that more or less sum it up?
Iu spacing is generous for fader centers but you can put some switches down between them.
Most big desks I see are right around 1U spacing. The mute and solo switches can perhaps float in there someplace, but I also like the big, wide fader knobs so I don't see spacing as a huge problem.
0dbfs said:
I also thought about instead of using a square chassis for channelstrips, to slope the rear at an angle so you get that nice console profile. You don't get as much space/depth near the bottom for your PCB's though. I/O connectors then go on the rear/side. I would post a sketch but don't have the means to do that at the moment.
The basic framework as I see it right now has three sections: the fader modules, which will be flat; the 19" channel modules, which will be sloped; and the meters, which will be either vertical or slightly angled back from vertical, depending on how the eye-height works out. There's no reason that the edge connector backplane needs to be parallel to the ground, so the whole backplane can be at an angle to allow for the module height to be consistent along the whole length of the module.
haima said:
Allen Farmelo has made a console using 1U API channel strips:
That is one of the cooler things I've seen in a long time. I like the design, although if I were to put a look I have in mind down to a few words, I would say less IKEA and more Airbus. I do love modern furniture design, though.
kepeb said:
I have a vote for the as yet 'premature' physical part if I may be so bold.
if you could fit the top vu/led and bottom fader parts into 3U height layouts like 5oo series
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
and keep the simple signal/peak light on the main strip even if you do end up with vu's option.
3U height may be indeed a perfect height. We will see when it comes meter design time.
Brian Roth said:
http://www.mouser.com/ProductDetail/Panasonic-Electric-Works/TQ2-5V/?qs=sGAEpiMZZMs3UE%252bXNiFaVCLW1ZA8WQBLGF3Vwl4YaEE%3d
Brian, those were the exact relays I was looking at. Certainly less thirsty than some others, but even so, adding 30ma per channel to the power supply requirements is no small beans. That's at least around 1.5A, just for relays. Perhaps when I add up all the current requirements of each channel that won't be a large percentage of the whole, but moreso than sharp pencil design for budget's sake, I'm trying to do sharp pencil design for power supply requirement's sake. That being said, I have no point of reference when it comes to console supplies. Are we talking 5A? 10A? 20A?
And to the rest:
It's been an extremely taxing weekend (worked 7-3:30 on Friday, drove out to Ohio immediately to attend wedding, then back again yesterday at 7am to play a wedding back in Chicagoland, eesh) so I apologize that I haven't moved this train along for a few days. I'm going to look into the CMOS switching option, which looks quite attractive, and I think the overload LED I may actually move to after the EQ section, where it makes much more sense to have it.
-Matt
