ruckus328
abechap024 said:Also be sure to clean all rosin from boards! Prior to placing them vertically. Haha the 10 megaohm input resistance don't like no rosin...
I actually just discussed this when someone asked about cleaning and supposed "no-clean" flux.
Just copy pasting what I wrote:
[quote author=ruckus328]
There's no such thing as "no clean solder", I don't care what Kester or anyone else says. Notice in thier literature where it says (should be ok for most applications). Well, we've had major system failures at my plant due to this supposed no clean crap, resulting in catostrauphic failures on equipment sent abroad (which was not an easy or cheap fix - try getting equipment back through Algerian customs, in the end I had to go over there, but that's another story). That was high voltage stuff, but we've seen issues with small signal here as well. Now everything gets cleaned, whether no clean flux is used or not. Anyways, "no clean" flux leaves a slightly conductive parasitic residue, when you start to get into high impedances is, you've basically formed a conductive path around your entire board, and it's juuuuuust conductive enough that all kinds of fun things can happen. Would there be issues with a design like this? I can't say, probably not, but for the 2 minutes it takes it's not something I'd gamble on, especially on something that's supposed to be high end audio.
You're probably going to need something a little more agressive than isopropyl alcohol though if using "no clean", I'd try methanol (any hardware store).
[/quote]
The basic jist is: at low impedances, a 10K inductive path from the rosin might not cause toooo much havoc, but at 10M impedances like you have, what happens when you put 10K in parallel with it? - all kinds of fun stuff.
