jdbakker
walter from waco said:Pay attention to your resistors. I've found very high 3rd harmonic in many parts. The Susumu 0805 RR12P are excellent.
Agreed; I've used them in the past in low-noise analog designs and am planning to spec them for this project as well. Pity that 1206 thin film parts are hard to get, but I expect that most people will be able to handle 0805s just fine as long as I don't pack them too densely.
walter from waco said:Delivery on many thin film in values we typically need e.g. 6K81 1/2W are problematic. The thermal mass of many 0603 and 0805 parts are small enough to create thermal effects. Be very, very careful. SMT may be "cool," but not necessarily better.
Yes. On one hand I'm looking at reducing the number of line items, like possibly replacing a 300-Ohm resistor with three 100-Ohm parts if the former value is used only once in the design (as I've found that both for manual assembly and P&P it's faster and cheaper to place more parts if they have less different values). On the other hand there are a few spots where I am brute forcing low voltage noise by choosing low-resistance feedback networks, and for those I may just go for through-hole after all, both for the reasons you mention and for the simple fact that quality low noise SMD power resistors are just silly expensive (although the jury's still out on MELFs).
JD 'decisions, decisions' B.
