Harpo
amazing work.
Just guessing, RFI cap C1 @ 470pF might be a typo. I'd expected about 47pF here. Why did you place these C1,C2,C3 caps after the common-mode choke and not as close as possible to the input XLR with ferrite beads @ XLR pin2/3 to keep Hf out?
Caps rating for C68,C70,C74,C75 @ 35V might get exceeded with assumed >=44V CT transformer.
Is heat the only reason behind using U4/U5 and U8/U9 instead of simple forward diodes as load isolators and getting away with U2/U3?
A jumper between R20/R111/R192 and servos out might come handy for trimming offset.
