ChuckHanning
Member
Hi All,
I built one of Bo Hansen's DIs recently and have been comparing them to the bumblebees I built previously.
I seem to have some distortion in the signal that I can't seem to figure out. I ordered most of the parts from Mouser but did make couple substitutions based on extra supply I had:
I had read previous thread in which they had distortion problems on the forum in which Bo had stated that two Zeners should be connected together with cathode instead of anodes so I reversed how they were originally installed.
I measured the following voltages in the circuit:
Thanks in advance for your ideas!
Chuck
- NPN transistor is BC184C from SCA N72 mic preamps I made a while ago, instead of BC550C
- PNP is 2N4403 as this was listed as substitute for PNP BC560C
- Output capacitor is 100 uF ELNA audio capacitor (instead of 10 uF). They don't make in 10 uF size. Perhaps I need another brand in 10uF?
- Capacitor from 1M resistor to ground is 33 uF not 10 uF. (original schematic was 1 uF then revised to 10 uF). I thought would improve bass response but perhaps this is a mistake on my part?
- Phantom power at where resistors connect to transformer is 36.4V (not 48V? I checked with two different mic preamps and is the same). Perhaps there is some voltage is dropped across secondaries of output transformer?
- Other end of resistors (connected to anode of LED) is 22V.
- After LED connected 3.9k resistor is 20.1 V
- At collector of BC560C is 8.24 V
Chuck
