DISTORTION METER AUTOMATIC GW GAD-201B ?
skal1
Birmingham,uk
Hi lads
could someone advise me on this, is it any good for checking DISTORTION on the out of compressor pre amps , say it can only check for distortion at AC voltage measurement at audio frequency range, from 20 ~ 20kHz. Frequency and voltage value are displayed simultaneously on dual meters, with measurement range automatically switching over full scale. Shortcut keys are provided for commonly used 400Hz, 1kHz, and 10kHz measurement. Output terminal feeds basic waveform (X) and harmonic distortion (Y) to external monitoring device. Residual distortion, including hum and noise, is kept at a minimum level of 0.03% .
quick respone would be nice, ending in about 20 mins
cheers
skal
