I suppose you mean you wish you knew someone in person with the body? All the pictures I posted in this thread are using the Tab body, and I could take some more pictures if you wanted.
EF12 versus EF14. I have used neither, but obviously both are modified circuits from the U47, not only because of the tube difference, but because they require a separate heater. I was talking with someone recently about how even the use of a separate heater probably alters the sound of the mic from the original, which makes sense to me as I learn more about how tubes work and their behavior.
Flea markets the EF12 as being the closest to the VF14 in sound, but we do not know their precise circuit. I was told by someone who no longer works at AMI that Oliver does not believe the EF12 sounds closer than the EF14, and indeed there is only EF14 info on the Tab site. Regardless, they use a Telefunken glass tube in their Lucas CS-4, which I have read sounds practically identical to a U47 when you use the same exact capsule and A/B. Of course, others have told me otherwise, but they are not transferring their capsules, and U47s differ from mic to mic.
There is a thread here on the forum about using the EF12, but ultimately the threadstarter (I think) wound up using an EF800 like I did.
Speaking of the EF800, I bought a couple more and they are quiet and sound great in my U47. I also went back and re-tested the second EF800 I got from Oliver, and that one is no longer noisy. I wonder if something was on the pins before. Regardless, I now have three backup EF800 tubes, so I think I am all set for life. I may get an EF802 to test, but I don't think I want to alter the circuit in my mic. I hate desoldering, and I feel fortunate my mic works as well as it does, so I don't want to mess with it too much. Besides, the mods Oliver makes for the EF802 are so small I wonder how much they really affect the sound. I may build another U47 with a 408a plus mods. Possibly the MK-47.
