Aaronrash said:
Awesome!
What tube and capsule did you use for your build? It really does sound good. Congrats man
Edit: oops I read your full post and got my answer
Do you know what voltage the capsule is being biased at? Maybe 60V like the original?
Yes, the capsule polarization is 60V. Actually a tiny bit less if I recall correctly based on my multimeter. Maybe 57 or 59V.
Also of note, I am using remote pattern switching, so if I disconnected the rear diaphragm, perhaps the sound would be a bit different. They say the s/n ratio improves, although I am not displeased at all with my noise performance. I'm shocked it's so quiet, especially considering my inexperience.
Aaronrash said:
Ok so I'm not trying to hijack the thread but I figured this would be a good place to post before I start my quest to building my U47. Now I know allot of purist believe that it's not a 47 without a VF14, I have to say... I had the chance to hear a Flea U47 with a EF12 against a vintage U47 with a VF14 and to be honest I preferred the Flea with the EF12 tube. It sounded absolutely amazing and I told myself I have to have this sound.
So my plans are to use Oliver's schematic with the alternate power supply. A Flea F7 capsule and the AMI transformer as well as kit of course. The only problem is, I have not been able to find much technical information on the EF12 and I'm not even sure if it will work with Oliver's circuit. But I know Flea has figured it out and that's how they sell their mics so I know it's possible
Aaron
Can you describe the difference between the Flea and U47?
You might want to check this thread - http://groupdiy.com/index.php?topic=42566.0
I have not read the entire thing, so I do not know if the answer lies within, but it seems like the perfect place to start. Definitely keep us updated on your progress.
I know that ultimately I decided the EF12 was too big of a project for a guy like me. This U47 was my first mic build ever, and I decided that the EF800 was a "safer" choice considering the Pearlman, Wunder GT, Oliver's schematic, and other builds I've seen online all use it. It's also cheaper than the EF14 or EF12, and I read that a 47 clone w/ EF800 supposedly fared well against a real U47 in a shootout. I figured that the EF800 being the glass tube descendent of the VF14 was good enough for me.
Does anyone know where I can buy tested EF800 tubes? To recap, I started this project with 2 EF800 tubes. One of them you can hear in my samples. The other had a very different frequency response, but was also much noisier. I don't know if the sound difference was a result of tube age/use/condition, or if these EF800 tubes vary a lot. If anyone has any info, that would be great. Being able to try a tube with a similar freq response as the noisy tube, but without the noise, would be very interesting.
