Hey Aaron,
This is an interesting article with comments from Mike Castoro, the founder of Wunder Audio. He's made a couple of U47 inspired mics:
http://recordinghacks.com/reviews/tapeop/wunder-audio-cm7/
I totally agree with this statement: <Castoro says there are three primary elements used to create the U 47–plus sound: the capsule, the transformer, and the tube… in that order.>
Note that Wunder/Castoro uses EF14, but also make a glass tube version too. Oliver's alt schematic calls for EF14. Flea uses EF12. I have no idea what the difference in tone is between EF14 and EF12 and EF800/802/804. Klaus Heyne says that no U47 will truly sound like a U47 without VF14M, period. Who's right? Hell if I know! I know my two new Eric Johnson Stratocasters sound and feel VERY, VERY much like my '57 Strat. Close enough that EJ is playing new Strats and leaves the old ones at home now. And he wouldn't do that if he felt there was ANY compromise. EJ is a no-compromise kind of guy when it comes to tone. With all due respect to Klaus, I don't subscribe to the idea that a great Strat (or mic) can't be made without the original components from the 50's.
I'm using a NOS Telefunken EF802 tube in my U47-ish build, with Thiersch PVC capsule and TAB transformer. This may sound lame, but if Tele EF802 is good enough for Oliver and Terry in the Lucas CS-4, it's good enough for me. I agree with the comments in this thread about how different tubes can sound different though. I thought that was cork-sniffing, until I actually tried different tubes, recorded the results and listened. Tube noise, microphonics and frequency response can vary pretty dramatically when in tube mics, more noticeably than in guitar amps, for example. One thing I've learned is don't build a mic without two or three tubes to try. Sorry for that expensive bad news! Just ran into this on a TAB C12 build. First Telefunken tube had low gain and was noisy, next tube of exactly the same type was money. This is really something to consider for the DIY tube mic builder, and something that sets the pros apart from guys like me. The pros have 100's or 1000's of tubes to try out before they find "the ones". Read what Klaus Heyne says about tube replacements on the REP forum.
FWIW, I'm in Austin. Maybe once your mic is done we could do a little comparison, especially if you use the same capsule and transformer.
Looks forward to your posts on the EF12 build. Hell, you may end up changing my mind about EF802's....
Robert
