Pip
Melodeath00 said:After another two days, I still have not been able to re-create the clipping, so everything appears ok for the time being. I am uneasy that I was not able to figure out what was causing the problem.
I did notice that when I turn the PSU off, the audio clips. Is that normal/expected?
There is a lot of handling noise when I hold the mic. I'm going to do some testing against other mics to see if it's out of the ordinary.
How important is it to connect the shielding in the Gotham cable to the Ground pin of the Binder connectors? Would this solve cable handling noise?
I am basically considering the mic done, except for the following list of items.
To-do list:
-Try more EF800 tubes
-Install internal true cardioid switch
-Further secure capsule mount (it tilts the tiniest bit when you tilt the mic, which you can hear as a tiny, tiny thud int he sound. Shouldn't be an issue at all unless you're singing with the mic in your hand and moving all around, though haha
In the meantime, check out the clips I posted in the post above!
And here's a nice little picture
PSU question answer is yes. True Cardioid switch is whatever. Handling noise is and always has been a problem with this mic not to worry about it. The capsule though should be mounted properly at some time. Not the end of the world but I myself would not leave it like that. Fixing this can only help the handling noise issue.
Now the shielding issue. I assume you mean the copper braid. Which in this application is the drain. Is it connected in the circuit at all now. Because it is not the ground but it is how the EMI and RFI (electro magnetic and radio frequency interferance in other words inductive forces) are kept out of the cable so it must be connected to the ground scheme on at least the PSU side of the issue. No it will not stop handling noise much as that is more a function of the capacitance of the cable than other factors.
