microx
I like analog tape and all the nice old machines etc. I had no bulk eraser so I decided to make one. I took the mains tranny from a scrap 750 watt microwave oven and cut off the high voltage winding straight through the laminations leaving just the primary, in my case 230v.
This leaves an erasing face, but you cant just connect the coil to the main supply as the coil does not behave in the same way as before. I used a Variac and found that 30v gave a current of 4.5amps and the coil did not overheat. Fixed it to a board and included a pin to mount the tape reel on and two revolutions totally erased a spool of tape.
If you do this using a 120v tranny the I guess you will need more like 15v at 9amps.
Steve
Steve
