john12ax7
Foam has gotten a bad reputation due to the prevalence of 2" wedge. If you compare a similar volume of foam to mineral or glass wool the performance is just as good, sometimes better.
Would you care to elaborate? What is the "danger"?cyrano said:The big danger with foam on a hard surface is that it could create a triple leaf system.
That's certainly fine for midrange absorption, but here the subject is diaphragmatic absorbers, that are specifically aimed at eliminating LF resonances.That's why I use mineral fiber board. Thickness 4 to 6". Less than 4" is useless.
I fully agree. I see too many people installing a standardized kit and thinking they(ve solved their acoustic issues...But most important for me are measurements. I can't hear everything, like people with golden ears can. But I can see what's wrong in a graph and, more importantly, I can see where it's coming from.
You mean, drilling holes in your mixer?And sometimes, it comes from the desk, not the walls. If it's the desk and the speakers are also on the desk, sliding them a few inches to the left or to the right could be enough to solve reflections. If it's bad, replace the desk surface with a perforated one.
cyrano said:Besides, getting foam that is actually useful is next to impossible. You would need high density open cell foam and that's not common in the marketplace. I tried to get some, but the manufacturer told me it would need to be made, or I could wait for leftovers from another order. Even those leftovers were expensive.
abbey road d enfer said:You mean, drilling holes in your mixer?
abbey road d enfer said:Would you care to elaborate? What is the "danger"?
DerEber said:Open cell foam can be obtained easily at stores where they make cushions. At least in my area.
It's not a total bargain, but much cheaper than the basotect stuff.
It's also likely that they have a much better glue for you than the stuff you can buy at the average hardware store.
best,
Stephan
Again, I need some explanation; what is a double or triple-leaf? Certainly you don't mean a joint? ;Dcyrano said:A triple leaf will typically result in less absorption when compared to a double of comparable size. It's much harder to calculate too
I'm not sure I follow you. Three layers of identical material is bound to be more efficient than two layers. Now, if you mean layers of different materials, that's a whole new subject, because the motivation for doing so is either to combine materials that have different frequency range (e.g. rock fiber for mids and highs and lead for lows), or sandwiching materials in order to realize a resonant system, where the resulting absorption is not the sum of the individual parts, but rather the result of a complex (2nd-order damped resonator) interaction.cyrano said:Double leaf is 2 layers. Triple leaf is 3 layers of absorption.
Do you have a specific example?You might get lucky, but sometimes 3 layers are worse than 2 layers.
I've met many of these guys who walk in the room, clap their hands and draw the acoustic treatment on the back of an envelope. Half of the times it works, half of the times it doesn't and the guy doesn't know what to do.I have a friend who is a professional acoustic engineer. He measures far less than I do, but he's done it often enough over 20 years to "see" where the boards need to go, or to guess what to change in the geometry of a speaker cabinet.
Thanks for the clarification.john12ax7 said:For soundproofing the leafs refer to mass separated by air cavity.
How's that?The danger of a triple leaf is that you raise the resonant frequency of the wall system which decreases isolation at low frequencies.
abbey road d enfer said:How's that?
Indeed. That's because there is a space constraint, not because it's a triple resonator. If space was not constraint, a triple system would be more efficient than a double.john12ax7 said:If you have a 12" air gap and decide to add mass in the middle you now have two 6" gaps and have created a higher order system with a higher resonance.
abbey road d enfer said:Indeed. That's because there is a space constraint, not because it's a triple resonator. If space was not constraint, a triple system would be more efficient than a double.
abbey road d enfer said:I'm not sure I follow you. Three layers of identical material is bound to be more efficient than two layers. Now, if you mean layers of different materials, that's a whole new subject, because the motivation for doing so is either to combine materials that have different frequency range (e.g. rock fiber for mids and highs and lead for lows), or sandwiching materials in order to realize a resonant system, where the resulting absorption is not the sum of the individual parts, but rather the result of a complex (2nd-order damped resonator) interaction.
I'm not saying your friend is like that, but a good measurement kit is definitely a must for someone who wants to make a living out of it.
What I see is that, given a certain depth, going triple is worse than double, which I totally agree with. Now, if the triple-leaf was designed with the constraint of maintaining the lower resonance, the performance would be better; indeed, that would involve increasing depth.john12ax7 said:Not necessarily. The issue tends to come up when modifying existing structures. This link shows an example. By adding spaced drywall to an existing concrete wall you have both added mass and increased the depth of the wall, in general good things, yet low frequency performance has now been destroyed.
https://www.soundproofingcompany.com/soundproofing101/triple-leaf-effect/
I would guess they had plans of the room? Strictly speaking, one does not need to "visit" a room to design acoustic treatment, as long as plans are established and verified. For soundproofing, preliminary measurements must be done, though.cyrano said:None of those cared enough to even visit the studio,
We all know (do we?) it's utterly useless, akin to kicking tyres when assessing a used car.let alone clap hands.
That's right. Acoustic treatment materials are inexpensive, it's the labour, particularly in terms of making it look nice, that is costly. And final tuning.1/3 of the price was for measurements before, during and after.
I think it's Eric Valentine who designed a mixer with an absorbent top. So no drilling required.
