Gus said:
I just simmed some values. Try a >= .01uf in series with a 50 meg. Connect one side to the center and the other side to ground. The high pass circuit a guess as to what Oktava might be doing
I think I get it - If I understand it is like you use a big enough capacitor to appear as a short circuit to all frequencies, then you put a resistor in to work as an RC network High Pass filter with the capsule capacitance of 40PF. is that right?
So the knee you chose was 79Hz?
I changed that and put .020uf and 22Megaohms, which is giving me a 180 Hz knee (down 3 db at 180 and 6DB per octave below that?). I think the .010uf would have worked. But 55Meg is too much (that means it is only down 9DB at 36HZ, and it doesn't seem like that is not enough to prevent overloading the head amp when wind hits the capsule).
It is very hard to measure but I can hear it, and it sounds right gentle and good, and really reduces pop clunk bam wind noises to just noise.. no overload. I may need to lower the frequency of the Knee a little, it cuts the proximity effect bass a lot.
But it works great, and is a great use for all these Oktava Mk12 pads, which I hardly ever use. Maybe I will make a couple of different knee frequencies in different pads.
