Hello,
You guys a pretty deep in loudspeaker design - I am newcomer to this group (altough I happen to know a bit from loudspeaker design myself and could perhaps help) and I am bit unsure if I should put my 50 cents into this discussion - You've been directing fearless TomasJ to right direction
However, I did read from somewhere, that TomasJ, You're trying to make a sound replica of Yamaha NS10. Is this still correct assumption?
So many things affect to the sound, "timbre," of a loudspeaker. It's drivers, cabinet, cabinet materials, acoustics, driver placement, cross-over components, etc etc.
The only way to replicate NS10 would by copying the design as well as you can, starting from identical drivers, then continuing to dimensions. However, like anything else legendary - someone's done it and posted a great article about it! And it's not even that hard. NS10 drivers should be available at Ebay, rest is more or less just woodworking.
Google search for "Yamaha NS10 DIY" gives you so much to read, but I enjoyed this one:
http://mnats.net/ns-10_clone.html
Good luck!
