audiomixer
yeah. but you will probably end up in the 4 ohm region, as there is no obvious reason to come below your LF drivers impedance. technically it's possible, but in your case not probable... the mid / high section will have a higher impedance, but that does not matter. think of the minimum as your highest requirement towards the amplifer.... it has to deliver significant amount of amps, which at least in the past was a problem. high impedance speakers require more voltage (always for a given power). so that can be a limiting factor as well of course.
- Michael
- Michael
