mhelin
The Proteus is based to the Wilson Audio CUB speaker:
http://www.wilsonaudio.com/products/cub/index.html
I think Tony just happened to have some drivers available which he used to make a similar one. Anyway, the point with this design is the great sensitivity you get with the drivers used. Tony used now obsolete CB17RCY/P's with 91 dB sensitivity. All new Seas 7" drivers CA18RNX etc. drivers have the sensitivity of 88 dB or less so they won't directly replace CB17. With active crossovers and biamping you can still use the less sensitive drivers; CA18RNX or L18RNX/P (with phase plug) could be used here with a success I guess. Regarding the in-wall mounting you just don't have to do anything with the baffle-step compensation. In passive crossover like used on Proteus it's a little bit more complicated. In an active speaker you just set the crossover point and tweeter vs. woofer levels. Can't go wrong easily.
If you want to use similar tweeter as in WA CUB you can still have a Focal (now gone) style inverted dome tweeter made by Celeritas here:
http://www.clofis.nl/nl/celeritas/celeritas_overig.htm
ps. This direct image link from page 1 sometimes freezes this thread:
http://img450.imageshack.us/img450/7527/SOFFITframesnewtannoypos.jpg
