mhelin
[quote author="Marik"]Yes, in fact I start reconsidering things and thinking more in Seas Excel direction.
Arguably, both are the very best speakers of their size, in existance, and both are... very pretty.
Now, only decide W15 (5'5") or W18 (7"). Both have their very strong points.
The main question--are 7 inchers too big for near field?
DISCUSS!!![/quote]
There are many good nearfield monitors with 7" woofers (and bigger) like the Dynaudios, so they are not too big. Also the the W18EX Excels are very difficult to use, some interesting comments here (in chapter "Designer's Comments"):
http://www.northcreekmusic.com/Pegasus/Pegasus.htm
(about the problem with the low pass & notch filter which creates a second high Q resonance). Another problem may be that metal cones generally have more directivity than paper cones (due to the pistonic behaviour), so at crossover frequency there will be a peak in off-axis response. However, when designing a pure near-field monitor the preferences are different (I propably haven't considered that enough), and the off-axis response is not as important as the on-axis response and the coherence of the sound field. So you want to have the woofer and the tweeter as close to each other as possible (so the possible waveguide must be very small like with Genelec 8020's, or no waveguides are used used at all). Anyway, I would prefer 5" woofers the for near field use except if I want to hear lots of bass frequencies. Even then a subwoofer is a better option. Also the W15 is much easier to use. There seems to be a new paper cone 5" Exel ( http://www.seas.no/Product%20bilder/e0041.htm ), looks like the CSS full-range.
DISCUSS!!![/quote]
