ron_swanson
BerndVP said:Hi! Thanks! Was indeed what I was looking for
Curious, what happend that rendered your power transformer dead? I've never lost a power tranny even when things went wrong.
lennieh said:Quick question for folk that have built this.
Which rotary switch did you use for the 24 step THD switch?
The v1.1 BOM didn't specify a particular switch. I got a pair of a pair of Blore Edwards switches. But cheaper than the Elias and very sexy looking...ron_swanson said:Are you referring to the Threshold switch?
I used what was indicated in the BOM... A ELMA 04-1130. Is there a reason why you don't want or can't use this switch? Arguably, this switch is on the expensive side, but it is quality.
Cheers!
lennieh said:The v1.1 BOM didn't specify a particular switch. I got a pair of a pair of Blore Edwards switches. But cheaper than the Elias and very sexy looking...
Hi perfect thank a Lot !This is the only photo I have of the innards of my build... hopefully this will helps...
Cheers!
I guess technically a on-off-on would have a center position with no connection. I used a on-on with no issues.Hi, next question :
For the comp Attack switch,
On the manual : SPDT ON/OFF/ON
But on a front panel is only '' Fast and Slow ''
It's a mistake ? It's two SPDT ON/ON switch or what's the center possition ?
Best
Im guessing you have the newer 1.1 boards? My build was a 1.0 and in that build the documentation was in error where the LEDs were shown to be wired backwards. Can’t say how that may or may not apply to the newer boards. Hopefully that issue was fixed. Hope this helps some.Hi all, I finally got my boards for this after ordering at the end of February. I'm in the process of building them and hit the point where I wired the PS to one of the boards. I'm noticing that the LEDs are getting -24V/Gnd. Is that correct?
Also kind of wondering about Egprod's question above..
Register today and take advantage of membership benefits.
