Ok! Maybe I missed it but there was also a Shoeps RF mic series, CMT 20.
https://taperssection.com/index.php?topic=196830.0
Some fascinating details there from DSatz.... thanks for the link.Ok! Maybe I missed it but there was also a Shoeps RF mic series, CMT 20. Details here, don’t know if it’s viewable to non-members.
Neither did I, although I'm not a historian. I wonder if KH has some knowledge ot it.never knew there was once a Schoeps RF mic.
They do not.I wonder if they use the same Sennheiser 'push pull' type capsule of the later MKH models?
Ah, good thought, possibly a clue.What I have discovered is the ones that collapse when a polarisation DC of more than 50V is applied, seem to perform best for this RF type project.
(I'm guessing they're lower tensioned capsules?) .....
This thread has sparked my interest and so I bought these to learn a bit more.
They are fairly common but my work has been concentrated on traditionally polarized capsules and so never gave RF mics much thought except when I have used MKH40's I have always been impressed by their clarity. Symetrical capsules are also interesting. The MKH80 is an incredible mic.I'd have thought you'd seen a fair number of these over the years. What is the view from your side of the pond? Not common?
Are you sure about that?They do not.
I have constructed a 'figure of 8' version of the RF.AMX10 circuit by using a dual membrane capsule. I replaced C4 with the second side of the capsule. So the bridge is essentially 'balanced' in this configuration.Single Diaphragm, Push pull is the sensible way to design a capsule for an AM mike ala Baxandall. My single remaining brain cell can't quite figure out if this is equivalent to the 'new' Sennheiser circuit.
The company Farnell is in Russia and buying from them does not cause any difficulties. I would be happy if you would share the list of components you are talking about:
I understand the purchase scheme very well, it's not a problem. It's up to me to choose and not make a mistake, even knowing the markings.You have already seen - and posted a copy - of my list of CPC (Farnell) parts... All the manufacturers series types are included on that list.
You simply need to look at the catalogue and order the specific components you need from the component types on my list.
You will most likely need to buy the resistors in batches of 50, but most other components should be available individually.
