the tube support circuit is not glued, but it stands as a rock !What is a “hoops”?![]()
![Grinning face with sweat :sweat_smile: 😅](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f605.png)
I always have to smile about the term “Audiophiler”.The 1uF MKP is what I got in stock...
I'm sure you're impatient to know about sound tests @rock soderstrom ...I always have to smile about the term “Audiophiler”.
They've changed the design a bit, but I often use the original Audiophiler caps. Nice and cheap, I haven't noticed anything negative yet. I particularly like the 10uF type because it's not that big.
Ahh, I see.the tube support circuit is not glued, but it stands as a rock !![]()
Yes, I will build one, just to see what the mods will do to this circuit. I have just ordered the CRD E352s...I'm sure you're impatient to know about sound tests @rock soderstrom ...
are you gonna build one for you too ?
I've oredred 10 x E-352 (and a 10th of E-562) on Ali Express and they seem to work (10€ shipping included for 10 pieces)Yes, I will build one, just to see what the mods will do to this circuit. I have just ordered the CRD E352s...
But this must not happen, check your connections and solder joints. This sounds like a contact problem, possibly to ground. Also make sure that your body does not accidentally touch any unwanted connection/contact point in the mic. I've had that too...Hum... Plate voltage has changed from 56v to 77v now... ? The other voltages are the same as before
The plate voltage goes down -2v / -3v when I hold the mic (and so add my body (?) to ground)
If I have understood Thor correctly, then around 60V. But much more important than the exact value is that this voltage is stable. Over 20V DC fluctuation is not ok.Which plate voltage should I get ?
Hmm, is there a dedicated ground wire in your 5pin (or 7pin) XLR cable?The shield is connected to ground on PSU side and to the mic body at thé mic side (but not to mic ground side)
B+ = 90v
Polarisation caps. = 58,28v
Anode volt. = 56,25v (thru E-352)
Cathode volt. = 830mV (thru 235Ω to ground)
I haven't put 1GΩ from grid to ground... capsule is connected straight to grid
My english is not strong enough to understand the joke, sorry...Like the Hong Kong guy who's GF had a black baby 9 Month after the USS Hancock made a port call in '66 said: "Sum Ting Wong!"
Is all "loose metal" tied to Audio ground, nothing but audio ground and nothing else?
Thor
Don't understand too about "loose metal"
The mic body is not connected to 0v but the shield is (see my drawing please)
Sum Ting Wong is mock Cantonese - Some Thing Wrong
See attached please : 0v is connected to PSU enclosure AND cable shield > (mic side) 0v is connected only to 0v mic and shield is only connected to mic bodyLoose Metal is any piece of metal that is not explicitly connected to something. Floating would be a more technical term.
So where is it connected to?
Attach files
Thor
Earth is not yet linked...So Mic-body = Shield and Shield = PSU Case = Earth?
How do you link Audio GND and Earth?
Thor
