Earth is not yet linked...
I "loose" 11v thru E-352 so 90v before and (last measurement) 79v after...
I noticed also that I get 160mV between PSU ground & mic ground...
@thor.zmt you didn't comment the possibility to put 2 x 1N4148 (for ex.) in serie to get 1,2v at cathode...
100R (1w) + 100nF (MKP10 > I have several in stock)Put 100R/100nF in parallel between chassis and earth.
Thor
Ground is connected to shield at PSU side (only) : should I connect it to shield at mic side too ?That is a bit on the low side. Maybe lower the Cathode R.
We like it to be appx 60V
Brrhhh.... That's wrong.
Thor
Lower the cathode R to... 200Ω ? 180Ω ?
Adding 1KΩ in // with 235Ω = 190Ω
BTW the HV doesn't get down to 0v...
After 20mn Hv powered off 27v are still present : I should put a charge R after the last 1000uF (56KΩ ?) to "empty" the HV in the circuit...
*612mV / 188Ω = 3,255mA
The cathode R has "lost" 100Ω (so 235Ω -42%) but plate volt. doesn't react so much...
Should I still decrease cathode R to 100Ω ? or less ?
The polar. is ok (+58v)
The current thru the tube is ok (3,18mA)
What's the problem to get +75v on plate ? since it can handle max. +120v
Ok but what about these 29mV on ground ?? not normal...Yes, the grid leak bias takes over.
I guess 75V will have to do.
Put 120 Ohm. Leave at that.
Thor
Should I put 1GΩ from grid to ground ?
