Hi there,
I just wanted to ask if someone of you is able to draw/ modify pcbs? Im going to modify my console but need some help, as Im not a DIY-crack. I got the ideas and need someone who has the knowledge. I would like to give you an little example: I will integrete an Compressor (1176 DIY) with variable Ratios in every channel, so the pcb has to be modifyed. I have also some routing changings in mind, that I need to check with a pro.
Anybody out there who wants to help me?
