Drip opto 7 stereo build ... Problems ..
I was wondering If one of you could elaborate a bit on how to hookup the VU meters, link and bypass switches for the Opto 7? I have completed the build up to this point. It has definitely been a labor of love getting the Opto 7 built! For the bypass switches, I do see there are green terminal blocks installed above the bypass SMA connector on each channel PCB, are these to be wired directly to the bypass switches on the front panel? There are also terminal blocks above the 6.3V SMA connector on each channel PCB. Any help with this and properly connecting the VU meters would be greatly appreciated!
Cmac
    149.2 KB
    223.9 KB
Cmac
I tried to hide cabling as much as possible, but on the following pic you can probably see how the cables are wired to the switches.
Hi... My Build of the Opto7 is almost done. The bypass switch is connected as followed. You have to connect the 6.3V of your Power PCB over a Switch to the Sma Bypass connector.
Greetings Cream
Hello, would you by chance have a photo of the front panel wiring? This is the last step for my build to be complete! Thanks much.
