justinheronmusic
Rocinante said:So on the below version of the 1081 amp there is a ferrite bead going to pin one of the ba338 and a 82v diode? after the ba338 stage along with another resistor; R6 which goes to BN? I had used this schematic which is different then others to design my pcb (hence the confusion). Are these components unnecessary then?
I can't say for sure. I, too, saw that schematic; being that it looked vastly different from the original BA312 scheme, I decided not to use it. The ferrit bead, I believe, can be omitted - that is a part of the scheme that can be cross referenced with the original BA312 scheme - though you may want to cross reference it with Tommytones Ten81. Same for the 82v diode; and for that matter, the entire filtering section after the BA338 should be cross referenced as well. It looks a lot different then what is on the BA312 scheme.
