It is a possibility; however, this type of "presence" hump is quite common in most condenser mics. here it seems to be limited to about 4dB; many cheap condenser mics have even larger humps and tend to sound brittle. 4dB is typical of many good quality mics that don't sound too harsh or brittle.tonedude said:Maybe the perceived lack of bottom is a result of characteristics of the capsule, and then especially relative to its raised frequency curve from 2000 and up?
I can't really imagine the tube circuit exaggerating the phenomenon (except what I mentioned previously about the increased tension).And maybe the capsules character is exaggerated when it's combined with this actual tube circuit in the mic?
It is almost impossible to conclude anything from these graphs, since we don't know the real accuracy of the test rig. The fact that they are produced with CLIO makes me suspect they are produced in a less than ideal acoustic environment - which doesn't mean they are useless, if they make comparative measurements with calibrated mics.When googling I found the below frequency chart in a "degree thesis" concerning the development of a non tube version of the EHR-1. I don,t know for sure if the frequency chart is done with the tube circuit or the circuit under evaluation (my guess is its done with the "phantom" version under development..).
The apparent dip at ca. 250Hz is a tad puzzling; I'm not sure it can be attributed to the capsule...
