metalockpick
See that big ground symbol connected to the Center tap on the schematic? Connect directly to the big filter cap negative for best performance. Not sure how you were getting any HV without it. Or bias!
What do you get on pin5 with no power tubes installed?
If using a full wave rectifier, yes. I'm using a bridge rectifier with the negative DC going to ground. As I said, I can rewire the transformer with a center tap, and I will right now.See that big ground symbol connected to the Center tap on the schematic? Connect directly to the big filter cap negative for best performance. Not sure how you were getting any HV without it.
Bridge... that's tricky.At pin 5 no tubes installed, with red probe in pin 5 and black to ground it's 100-200 millivolts.
There is no bias voltage (except a few millivolts no matter where standby switch is located. I know the tubes will redplate and then melt down without bias voltage hince why I'm trying to get bias voltage (it's done ate one set of tubes lol)In all 100w marshalls you should see the negative volts at the grid before standby is switched to on ,
some of the earlier 50W models tap the bias supply after the standby ,
If you have no bias volts on the powertubes , yes they will red plate within 30 seconds ,then procede to melt down .
Check the polarity of your caps in the bias circuit. They need to have the negative side connected to the bias supply and positive to ground.
Get a highlighter pen and trace out your bias supply on a paper schematic. I am sure you will find a missing ground or some other gremlin.
Can you post a picture of
1) your el 34 tube sockets
2) your bias supply circuit
You should analyze the circuit. The voltage taken from the transformer varies between 0 and B+, so never negative.
2 possibilities:
There is another possibility, which involves completely redesign the topology of the bias circuit, which would also imply a lot of trial-and-error for adjustment.
- revert to half-bridge rectifier
- use a separate winding.
Ideally, the center tap is grounded, the outside lugs each go through diodes, with the anode inside together, positive high voltage. One side has the reverse biased diode and resistor for the bias supply. With this circuit, you'll get positive voltage from the full wave, and you'll get negative bias from the single diode and capacitor. Just get that working. I believe in you! You can do this.
I understand that, which is why when I was using (4) 1N4007 for the power supply I had the center tap. When I switched to the bridge rectifier I was only using one pair of the 325v tap, the second was going to my bias supply. Either way, there is no negative voltage.You CAN’T use a bridge rectifier, and still derive negative bias volts from the same winding.
With a bridge rectifier, the negative side must be grounded to complete the B+ circuit.
This means that in any duty cycle there is NO negative voltage available for bias.
It’s fine until you hit the STANDBY switch, but when that switch closes your negative half-cycles no longer exist.
With a grounded CT and full-wave rectifier you can do it, and that’s the schematic you have.
What’s all this about the transformer saturating?
Of course. You would need a different xfmr.The toroidal transformer isn't suitable for a half bridge rectifier, the data sheet says it will saturate the transformer and isn't recommended.
No. Consider the output current. The negative side of the bridge must be grounded to complete the B+ circuit.
If you are only using one of the secondaries for the B+, you can use the other for bias, but your voltage will need a lot of dropping. Again, ground the other end of the winding to complete the circuit.
No. Read again. It's not suitable for single-wave rectification.The toroidal transformer isn't suitable for a half bridge rectifier, the data sheet says it will saturate the transformer and isn't recommended.
