Ok, lets make sure I understand. If using one set of secondaries going to the bridge rectifier (requires removing the center tap) to produce my DC high voltage I ground the negative side of the bridge to complete the circuit.
Using the other set of secondaries I connect one tap to the bias supply, and then ground the other?
This is what I drew up guys. Would this be suitable and work?
Sometimes this easiest solution really is the easiest. Any reason why I can't skip the dropper resistor and single diode and jump directly off the negative side of my bridge rectifier for my negative bias voltage?
No, sorry. This is bridge rectification with negative grounded.
I think there is a big misunderstannding as to how you have wired the xfmr and rectifiers.
Your early description tended to indicate you used a full bridge, as in the South-West picture of the datasheet, but this last description tells different.
Would you please draw a good schemo of the actual arrangement that doesn't bias properly?
In order for me to have a center tap, it requires both HV coils to be connected together with the inner two (#2 and #3 grounded). As I'm out of 1N4007's now it's either wait for more or proceed to use a bridge off one secondary and my bias voltage off the other. Why will this not work?No, sorry. This is bridge rectification with negative grounded.
For correct operation, it's the CT that needs to be grounded.
As others have pointed out, ditch the bridge rectifier and use separate diodes plus grounded CT as on the Marshall schematic. If you've run out of diodes you need to stop and get some more, as it's the only way it'll work.
I do not have bleeders installed, however I'm comfortable discharging filter caps and always take every safety precaution! I am going to revert back to the schematic, and follow abbeys directions. But, for now it is working as I've posted.Abbey's shem is how a gazillion tube PSU's are wired. If that isn't working then that is what needs investigating.
Do you have a bleeder resistor on your B+ voltage. To discharge the B+ rail when powered off?
Older Marshalls have bridge rectifiers in them (not diodes) so not sure why (it's the only way it'll work)As others have pointed out, ditch the bridge rectifier and use separate diodes plus grounded CT as on the Marshall schematic. If you've run out of diodes you need to stop and get some more, as it's the only way it'll work.
Not sure why everyone says it won't work, because it does? Amp is biasing correctly now. I have however ordered diodes and I'll switch topology to follow the schematic. However, I assume the starting issue will be there and I'll have no negative voltage at the bias resistors again.
From your sketch it looks like you're using one secondary for HT and the other one (separately) for bias. Is that correct? If so you'll burn out the HT secondary as it only has half the required current capacity. You might have bias and HT voltages at the moment, but the first time you overdrive the amp you can probably say goodbye to the transformer.
Yes, you are right. If you use that transformer of that power, one winding is enough. And you can use the second winding for - bias. According to the schematic from your post 43. It would be good if you implement a standby switch so that you can first turn on the heating and set a sufficiently negative bias before turning on the anode voltage.
