The op valves do go to ground, however the bias pot doesn't go to the same ground, I can move it though.Are you sure the o/p valve cathodes go to ground. and it's the same ground as the bias pot is connected to?
Sorry, I missed your post describing the transformer. That's a heavy duty transformer! It shouldn't burn out, but I'd still be inclined to revert to the original Marshall schematic as it will share the current load between both secondaries.Even though each secondary is rated separately for more current then the amp can pull? Each secondary is rated for 400ma? Care to explain why the transformer would go if it's underloaded?
So the original xfmr is rated at 213mA, for full-wave rectifying.That was just a rough drawing, I do have a standby switch implemented. The schematic I posted was just to get a working bias supply. I can't wrap my head around why the transformer when even at half current capacity (200mA or half of max rated 400mA) would go though. Because even at half current, it is in spec for the amp (it's actually closer to the spec called for as it only calls for a 150mA (213mA max) HV secondary power transformer.
That's the 3rd possibility I mentioned in post #31. Making it work satisfactorily requires serious work.however you can use a bridge rectifier, however you need to cap-couple the bias supply to get it to work. Details are here:
http://www.valvewizard.co.uk/bias.html
It does not matter what the bias supply is putting out voltage wise. The only thing to tube "sees" is the bias voltage from the control grid to the cathode. That is what is important and the meaningful voltage to measure.
In my experience with Marshall’s, this always one of two things (if the bias circuit is wired correctly). Either a dc blocking cap has failed, or the pcb has broken down and is now leaking DC into the bias circuit. Either way, the negative voltage gets negated by the time it gets to the tubes. It looks as if you’ve measured all the bypass caps, so I wonder if there is either a breakdown in the pcb, or a carbon trace on one of the output tube sockets that is allowing a HT leak.
Throwing away half the current capacity of the transformer to feed a bias curcuit doesnt make any sense to me , even if a single HT winding is adequate for the job , the extra juice available on tap will make a difference at moments of peak power .
My friend, I've stated I've got UF4007's on order and I'll be converting the amp to follow the schematic once they arrive. However, as it currently works (after being told it wouldn't repeatedly) without issues so far I believe the issue is fixed.The best advice of several members who took the time to respond to your post is in black and white ,
your captain of your own ship , do what you want .
There's nothing facetious in what I said, there's no humor in it nor was it meant as such. If you're annoyed I call you "friend" well my friend, I'm sorry. I've said thank you, that I appreciate the help and asked to let the thread go now as it serves no purpose.I take umbrage at your use of the term 'friend' in that facetious manner ,
its fine I wont be responding to anymore of your posts .
You should admit that your communication was not very clear.I simply stated facts, one user stated it wouldn't work others said it would. Users made "guesses" and etc based on transformers specs they made up without even looking at the data sheets provided. T
