paulcheeba
- Joined
- Mar 29, 2017
- Messages
- 206
I don't know how you did this but you’re a genius Dude! I had basically thrown mine away until I understood how you subtly extended yours. It’s so good we have problem solvers like yourself or we would never get anywhere. Thank you so much, I have almost sorted it. Just waiting for some 50mm pipe as a washer.Got Poctops 251 PCBs today. It was easy to integrate the board into the AliEx case. It fits well. I mounted the board holder profiles to the capsule holder plate from below, not from above like the manufacturer does. The four washers used between the screw and this holder plate are used to lengthen the holder by a few mm. Then I used a 50mm PCV tube and cut 3-4mm thin pieces as insert lining to fill the space/length of the powder coated MicBody outer tube. Very easy!. Then the bottom screw cap of the mic body holds everything together as before, with a few mm more length to allow for Poctop's 251 circuit boards to fit. There is enough space on the top to easily accommodate a thick, fat axial 3.3uF 20mm DC block filmcap. There is enough space behind this fat axial film cap to accommodate the microphone electron tube. Holes for screws are usable to mount the PCB and there is also enough space under the tube for mounting a UTM0512 transformer, cutting the lower unused screwnoses on both sides away. Only the solder-side of the 7-pin connector has to be cut shorter and well insulated, otherwise 1-2 mm would protrude into the PCB area. And checks for shorting soldering connection with the frame.... are also necessary to check before finishing carefully....for sure -file.....That's it. No milling machine or the like is required.... I like it very much in this way... 30min work and you have a good solution for using these super looking Micbodies
Can I use my TBone Retro Tube PSU transformer with 115v & 115v primary and 175v and 9.5v secondary? Micparts use the same. Cheers Paul.
P.S. what size bolts for the holder plate.
