Ahhh but zeners dont have that ghostly etherial glow to signal out to you ,
of course your right all kinds of down sides to gas discharge tubes , they can go noisey or not maintain the intended voltage when they get worn out . Maybe a reclaimed neon from the disposable flash camera could serve as indicator the zeners are starting to conduct.
As far as the veer against disposable cameras goes , Im quite happy to take a bag of 20 fuji units for dismantling any day I happen to call by the store , thats 20 near new caps of the best quality , they even leave plenty of leg room so you can simply clip the component from the pcb and put into the tray marked 82uf 300v . Im swapping out all the garbage caps in my Chinese mics supplies for these asap.
Oh yes by the way , be warey the capacitor can remain charged in the flash unit for a longtime , it'll give you a nice little zap if your not careful. If your unlucky enough to make contact with positive and negative terminals with left and right hand it could very well stop your heart ,my advice is crow bar the cap with an insulated screwdriver tip before handling the pcb . the cap appears to have a memory effect where even after discharge through the zenon lamp voltage reappears .
all the other components of the camera go to plastic recycling even though there is a few tiny metal springs you could also make a collection of if you wanted ,
