DerEber
Wait, the whole thing if after (or in the middle) of Voltage filtering. So it makes its own thin right?
skal1 said:? if the current enters the tx primary is 14.5ma ,what is the current coming out of the cathode across the 220 ohm resistor
cheers
skal
Thanks for post !djn111 said:Hi,
In you respond on help etc. This is just a building report, and if you need all that info, are sure you want to build a tube project, point to point with 300V DC in it ?
All the info is in a few RS124 threads, start reading those the parts list is not very big, so easy made from the schematic.
Kind regards
