You have a problem either with the sidechain, or the sidechain signal isn't getting to the 6bc8. This is a very simple compressor so it should be quite easy for you to check for mistakes.
Ok, then can I omit the link between the two 39K resistors and the center tap of the input transformer, the two resistors acting as a false center tap?The values you already have on your schematic look like a good place to start.
Yes, absolutely... I was surprised at first but it is a praised compressor, so I guess it works just as well ?Is the input attenuator before the transformer in your particular schematic?
Rob Flinn said:If I pull the 6AL5 I have the waveform doing the same thing. Does this mean that I have little or no compression happening ? I have tried maybe 3 different 6AL5's.
Winston O'Boogie said:Secondly, I'm not quite sure why your output attenuator was causing the control voltage to only rise to 3.3 volts tbh?
Winston O'Boogie said:The simplest output attenuator would be a 1K audio taper pot across the transformer so you might give that a go. It's been years since but I think that's what I did on the Lisson Grove comp that was made for a while.
letterbeacon said:This is a stupid question, but how would you connect a 1k pot across the transformer? Do you mean a stereo pot? I'm using the Sowter transformer designed for the Altec 436.
