buildafriend
CJ? We need you.
dmp said:Is that a ground line to be wired manually?
tubologic said:Before you finalize the PCB layout please note there's a missing decoupling cap in the schematic, it must be connected after the 5K1 resistor going to the 72H choke and ground.
dustbro said:tubologic said:Before you finalize the PCB layout please note there's a missing decoupling cap in the schematic, it must be connected after the 5K1 resistor going to the 72H choke and ground.
I remember reading in the Radiotron Handbook somewhere that the choke will act as a decoupler, so one might not be needed in this instance. If I get any motorboating I'll know where to add one asap
buildafriend said:I was comparing the early fender champ models and one of the budget cuts made on it was the choke was removed and replaced with a resistor and a cap. Is the choke in the RS61 coming from the PSU? If yes, I would assume that the same revision could be made that was made in the champ.
