peter purpose
Marcocet said:Any ideas?
Not a one..... but swap out the amps for known good ones at the very start.
peter purpose said:Nice EQN page Mako.
peter purpose said:The small sockets are just pulled from a turned pin strip... hardly rocking horse poo and cheap as chips anywhere on the planet.
I'd suggest check the rotary switches with a multimeter. I just finished my pair, and had a similar problem in a couple bands and it was a mistake in putting the stop pins in. Once I figured that out, put the switch back in, they both work great. Awesome project Peter.Either the frequencies are all wrong, or some of the settings are dead etc etc etc.
Marcocet said:Okay,
Most of them are working great! Of the few i've had problems with two are most likely in the switches, or beneath them where the resistors were soldered. However all my attempts to remove either have the switches have done is pull up a bunch of the solder mask around the pins! Anybody have any advice on how one would go about desoldering and removing one of the grayhills?
-marc alan
Marcocet said:Anybody have any advice on how one would go about desoldering and removing one of the grayhills?
