dmp
I believe what you have circled as 2 is for a three pin header. If I recall correctly it terminates the output transformer with R37 if a jumper is installed (600 ohms). Look at the traces to see if this makes sense.
crisotop said:As far as I can make out R37 is the 600 Ohm load - is C61 (C62) parallel to R37?
canidoit said:Pete,
How much current does this build take.
